Is there any way to modify the toolbar I attached in the picture?
It seems like a great place to put some commonly used icons, but I can not figure out how to modify it.
thanks
Matt
There is only a preset subset available. When you use the RMB on the menu, it will show you the options including placement of the toolbar.
If you want a random set of commands available, I have used the quick access toolbar at the top. Unfortunately, even this toolbar is unique for every filetype.
Yeah, I feared you couldn't modify as I have been up and down through the options area and could not figure out anything, the only thing I do see is that the commands on the bar in options file does recognize them as "graphics toolbar". And the ReadThisFirst.pdf also says you can modify the toolbar, the limited preset is ok, but full customization would be better.
I did modify the quick access toolbar a bit, even tried moving it below ribbon, etc. None of that feels efficient for modeling though. So I use it for file access, exporting, etc.
Thanks for the input.
Matt
Happy to help.
You might consider putting parameters; switch symbols; and relations; and even measure in the quick access toolbar too. I find these very useful on many occasions.
And I hear you on the quick access toolbar location. As a matter of fact, I am all over the screen -mousing around- to do even basic modeling.
I think a general floating small icon toolbar that does not change between modes would be very helpful. If the toolbar command is not available, simply gray it out. I might just have to enter that as an idea ![]()
If you can vote on Ideas, please consider voting for this one:
