Issue in using Erase not displayed command
ms-6
6-Contributor
Hi all,
Recently I came across an issue, when I activate Erase not displayed command Creo crashes. I am not aware of the reason why?. Somebody could throw some light on this and help me?
6 REPLIES 6
mender
(To:ms-6)
What release/build are you in?
ms-6
6-Contributor
(To:mender)
We use Creo2 M220
mender
(To:ms-6)
If the difference of 'recently' is that you have recently started working with models that came from a later build of Creo 2, then you may be experiencing the problem documented in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS246507
If this is the case, you will find your issue is resolved by updating to Creo 2 M240.
Did you have a chance to download M240 and test further, as per the article?
Amit
rubenvillarreal
(To:ms-6)
Sometimes the same thing happened to me. I notice that all start when I received a ¨fatal error¨ message. After that point, each time I used erase not displayed, Creo crashes automatically.
adbarkcity
(To:ms-6)
I am getting the same issue on assemblies that use several family tabled sub assemblies. It is really anoying. I am on Creo 3.0 Essentials. I cam from a company that used the same type of subs and assemblies and there we did not have this issue but we were on PDMLink.
