Can not use ampersand (&) text symbol?
  • September 19, 2014
  • 2 replies
  • 12481 views
Does anyone know how I can create an Ampersand (&) text symbol, or a shortcut to use it as text in a symbol? Creo does not allow "&" as text in my title block symbol?
    Best answer by Mahesh_Sharma
    Try this:
    In title value, type S > press CTRL+A > SHIFT+7 (For &) > press CTRL+B > W
    In Creo Parametric 2.0, whenever the characters & or @ must be display in the text of a note, type them twice: for example, type [See Views 1 && 2 @@ Sheet 3] for the note to read See Views 1 & 2 @ Sheet 3.
    Thank you Scott. I am currently using Creo 1.0. I am actually trying to edit variable text in a symbol. In this case it is my company title block for the drawing. When I type & or && the line of text blanks out on the drawing?
    Can you add a screen shot of your example? Want to make sure we're all talking about the same thing. Could be table text. note text, symbol text or parameter text.
    Mahesh_Sharma
    22-Sapphire I
    September 19, 2014
    Try this:
    It worked! Thank you!!
