I realize this is an old posting, but I am just now trying to find a solution...
I am trying to add multiple leader lines from both a text entry and a dimension radius callout in Annotation 18.1.
The cntl key didn't seem to work... Is there a way???
Thanks, Lynda
I know this is an old post but I was struggling with this too (on Creo 3.0) until some one showed me.
If it is a note just right click on the note and go to additional leader.
If it is a Geometric Tolerance, create it selecting one face to begin with and add all the values, datums etc.
Then Right Click on GD&T - Edit attachment, then when Mod options tool bar comes up select add Ref and pick the additional face.
