Not COG....but COB !!
jnanesh.sajjan
Hi
Is there any method to evaluate centre of buoyancy in pro-e?
Thanks in advance,
Cheers,
Jnanesha KS
fluid_density=.09FLUID_DENSITY9.000000e-02volume=VOLUME:FID_VOLUMEVOLUME5.131266e+01bouyant_force=fluid_density*volumeBOUYANT_FORCE4.618139e+00
I did this for a part one time and it worked pretty good... The point at which buoyant force acts coincides with the center of mass.
Sorry, a little bit cryptic on the last response:
Set up a parameter called density (or use MP_DENSITY)
Do a volume analysis on the part and save it as a feature.
Set up a relation mulitplying the two to get the bouyant force.
Do a center of mass analysis on the part. The center of bouyancy force will act through that.
