Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Is the component icon checkbox in the Product Structure tab going to be in PV 9.1? What purpose does it serve to open a file with the parent component unchecked? I would like to set the preference to open it checked but can't find it in the preferences.
