How to switch on quilt edge display in shaded view status?
I used to do that in WF4, the open quilt edges were highlighted in yellow color....(it was in View-> model display tab) but the similar option if available in creo, pls discuss how...?
that will be use ful while fixing complex quilt open edges
Mahesh,
one-sided edged have Letter color assigned in Hidden line mode. By default it is blue in Creo Parametric 2.0. You can change it using File > Options > System Colors > Graphics > Letter.
Then you can Export color scheme into .scl file and set config.pro option
system_colors_file PATH_TO_syscol.scl_file
Martin Hanak
Hi Martin,
my issue is exactly the below link http://communities.ptc.com/thread/42702?tstart=0
can you help... quilt edge visibility in shaded mode....
Mahesh,
I think you have two options:
Martin Hanak
in my organisaton creo 2 migration in progress and we consolidate issues.... will wrap up the issues to PTC... may get some changes later
Mahesh,
This is because of change in functionality from Creo 1.0. However you can use search tool to find one-Sided edges in part. Sreach > Lookin for Edge > Attribute as Type > value as One - Sided.
Hi Mahesh Sharma,
Good moring..
I tried and it shows all the one sided edges n the part,... meaning open edges in construction surfaces as well....
imagine a big part with lot features
even i was not using it till date...
thanks for the command
