Quilt edge display in creo2
mms-2
7-Bedrock
How to switch on quilt edge display in shaded view status?
I used to do that in WF4, the open quilt edges were highlighted in yellow color....(it was in View-> model display tab) but the similar option if available in creo, pls discuss how...?
that will be use ful while fixing complex quilt open edges
6 REPLIES 6
MartinHanak
(To:mms-2)
Mahesh,
one-sided edged have Letter color assigned in Hidden line mode. By default it is blue in Creo Parametric 2.0. You can change it using File > Options > System Colors > Graphics > Letter.
Then you can Export color scheme into .scl file and set config.pro option
system_colors_file PATH_TO_syscol.scl_file
Martin Hanak
Martin Hanák
Hi Martin,
my issue is exactly the below link http://communities.ptc.com/thread/42702?tstart=0
can you help... quilt edge visibility in shaded mode....
MartinHanak
(To:mms-2)
Mahesh,
I think you have two options:
  1. ask PTC support
  2. use some workaround, eg. select surface edges and create Copy feature (curve) using CTRL+C and CTRL+V shortcut
Martin Hanak
Martin Hanák
in my organisaton creo 2 migration in progress and we consolidate issues.... will wrap up the issues to PTC... may get some changes later
Mahesh_Sharma
22-Sapphire I
(To:mms-2)
Mahesh,
This is because of change in functionality from Creo 1.0. However you can use search tool to find one-Sided edges in part. Sreach > Lookin for Edge > Attribute as Type > value as One - Sided.
Hi Mahesh Sharma,
Good moring..
I tried and it shows all the one sided edges n the part,... meaning open edges in construction surfaces as well....
imagine a big part with lot features
even i was not using it till date...
thanks for the command
