Redundant GOTO line
breiter
Redundant GOTO line
All,
I recently updated our datecode to WF3 m200 x64from WF3 M120 x32. we noticed in our ncl file that we are getting a line that says "GOTO / 0,0,0,". In our ncl file prior to our datecode change this line was not showing, it would just show the first goto position. Is there a setting somewhere so this "home" position will not show up? Or is there somthing about the m200 datecode that is causing this difference?
Brad
Cedge
(To:breiter)
Hi Brad,
I think you need to check the "
Cedric
