Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Request for a Presentation file on ProductView Express
Hi, If you can share a power point presentation on the virtues of ProductView express, I would like to steal slides from it for use internally to promote ProductView Express at Midmark.
Please post directly to the forum on this thread.
Thanks!!!!
Andrew Amsden CAD\PDM Administrator Midmark Corporation 937-526-8770
