Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Does anyone know of a way to determine the thicknesses of all geometry intersecting with a line? That is I would like to draw a line at a given angle and see a report listing the component and the wall thickness (or thicknesses) of each component that the line passes through. Chris
