Returning information back from an external program called by Smart Assy
ptc-198847
2-Explorer
Is it possible to return values back to the SA Application after calling an external program/method?
With the PLUGIN command, I know you can pass arguments to an external program
1 REPLY 1
I'm guessing that you can't do that directly, but you could probably have the program you are calling via PLUGIN store data in a text file or perhaps a spreadsheet and then read that data back into SmartAssembly.
Design well!
