Standard Holes for surfaces
Not applicable
Dear sirs, I have installed my free copy of COCREATE Personal Edition italian version I need to perforem on solid surfaces standard threaded Holes M5 M4 M3 etc... Where is possible to find and download the necessary modules or library to perform them? And which is the procedure to update the program? Thank you very for cooperation.
1 REPLY 1
Not applicable
(To:)
In the Commercial version of CoCreate Modeling, you can use the Machining Module functions to create and modify threaded holes. This module is not available for CoCreate Modeling PE.
