Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
add_lower_level_comps_to_layer [no], yes Activates the Favor Current Layer option, which allows lower-level components to be added to top-level layers.
Brian S. Lynn Technical Coordinator, Product Engineering
