Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Ok, 99 times out of 100 I don't want to use the align angle constraint, but occasionally Pro/E will give me that constraint when I click two planes that are not close to parallel. Now, I want that and I can't get Pro/E to give it to me, even when the planes are quite a bit off parallel. I can't just pick 'Align Angle' either, how do I get it to show up? Doug Schaefer
Clear all of your existing component constrains. Next, try picking your constraints in a different order. The first one being the angle constraint you require.
Bob
