What kind of the causes that?
bduncan
SergDubrovskiy
(To:bduncan)
Rename file
e:\ptc\ProeWildfire5\efx\x86e_win64\efx70_wf4.dll to
e:\ptc\ProeWildfire5\efx\x86e_win64\efx60_wf4.dll
5 REPLIES 5
SergDubrovskiy
(To:bduncan)
Rename file
Sergey,
do you know if there is a bug on efx70_wf4.dll for x86_win64?
Becauso i have one machine running WinXP 32bits and I can run EFX.
But on my machine running Win7 64bits i got my Creo freezing at startup.
I´m using Creo Parametric 1.0 M010.
In Creo Parametric 1.0 M010 - OK!!!
set option efx_enabled - yes
EFX is enable on config.pro. I can start the software normaly with EFX disabled.
Tha trails file with EFX enable looks like this;
!trail file version No. 1500
!Creo TM 1.0 (c) 2011 by Parametric Technology Corporation All Rights Reserved.
< 0 1.182815 1533 0 0 998 1680 0 0 1050 13
!mem_use INCREASE Blocks 453107, AppSize 51844177, SysSize 62726128
< 0 0.968296 1376 0 0 817 1680 0 0 1050 13
< 0 0.968296 1307 0 0 817 1680 0 0 1050 13
!%CIWelcome to Creo Parametric Education Edition 1.0.
!%CDEFX PROFILES_ADV_LL
!Application (EFX_SL50): running DLL-mode user_initialize
!SL50: INSTALLPATH "C:\Program Files\PTC\Creo 1.0\Common Files\M010\efx"
!SmartLibrary 5.0 M290 - 2011260
!Pro/ENGINEER: 1.0 - M010
!Application (EFX_SL50): returned from DLL-mode user_initialize; status is 0
!Application (SmartConfigDll): running DLL-mode user_initialize
!Application (SmartConfigDll): returned from DLL-mode user_initialize; status is 0
And thats the image that freezes when I start Creo with EFX enable.
Anyway thx, I´ll try support/reseler or try with Win7 32bits.
I manage to get EFX loaded by uncommenting (puting # before) the line text_dir on protk.dat
Don´t know why.
