Wildfire 4.0 M050
bparrish
8-Gravel
Wildfire 4.0 M050
All,
We are looking to upgrade to 4.0 in the short term. I am looking to
start testing the release and I see that build M050 is available. So my
question is, are any of you using this build? Are there any known
issues that I need to be aware of? I will post a summary of the
response that I receive.
Brian
2 REPLIES 2
Hi Brian
We have been using M050 since it was released, the only issue we have
found is on cross hatching.
You used to be able to select 2 or more views and copy the x-hatch
across, it doesn't work in this cut.
Apparently it will be fixed in M060 (due at the end of December).
Apart from that its been pretty stable, we are running it with Intralink
9.0 M040.
Regards
Sarah Ford
CAD Designer
Tel. 01202 627200 Ext. 236
www.westwind-airbearings.com
Look on the PTC.com Pro/Engineer support homepage.
There is a bug with relations in M050. See TAN142812
