Wildfire 4 to Wildfire 3
ptc-1836512
1-Newbie
I just completed an assignment. I did the work in ProE WF4. I just found out my customer is using ProE WF3. Is there anyway to translate the file back to WF3 so he can open them? Currently I have both versions loaded on my computer (WF3 and WF$.) When I select the ProE Icon it automatically opens WF4. How do I access the WF3 software in the future?
8 REPLIES 8
Walter There has been several posts on going backwards and the short answer is not directly can you save to an earlier version. On your shortcut, you need to create a new icon (WF3) that targets the WF3 bin directory with the name of launch of Pro-E. I cannot say that the name is that it is pro-e.bat or ? Some people rename the start command during the installation. Eric
I have had success with the GRANITE-based Cross-Release Interoperability for Pro/ENGINEER from the free downloads section. Your customer will not be able to modify features that you have created, however they will be able to open them in 3.0.
U can save ur file in either IGES or STEP or even in NEUTRAL format tat available with pro-e to open the higher version file to lower version.
Going back to the original question. Someone told me that in this case, I might be able to save the drawings as .dwg files and then open them in ProE WF3. This method does lose the model tree. I have yet to try it. The customer worked with the pdf's I created.
Walter In a recent situation I faced the organization I work for uses WF3 and I received a file in WF4, but the saving grace on that one was that they included a dumb solid in the form of a step model. I had some geometry that I need some vendor input and I was able to compare their step model to my WF3 model. Unfortunately someone ends up doing double work if they need a parametric model in an older version of Pro-E. Even the granite way gives you a model without a history tree. At least Pro-E models can be opened in later versions of Pro-E compared to other CAD software where you must migrate the model to the latest release. Eric
