1 Reply
653
Views
| Hello folks, One of my users has just completed an evaluation of
Mechanica WF2's new volumetric heat...
1 Reply
653
Views
by
PAULKORENKIEWIC
1 Reply
535
Views
| Guru's... We are finally discussing making the move from 2001 to
Wildfire and are wondering if there...
1 Reply
535
Views
Is it possible to create a toolbar with the ProUI? More specifically,
has anyone used a menu pane to...
430
Views
747
Views
| Is there a way to asychroniz the ProMacroLoad inside an auxiliary
application? When I tried to call ...
747
Views
Of course a few minutes after I sent this I figured it out on my own. In
the Mechanica results windo...
422
Views
by
ptc-1140560
1 Reply
748
Views
| For those of you that use the ecad_hint.map file, I was curious whether
you create a single mapping ...
1 Reply
748
Views
How do I create a protrusion extruded in both directions up to separate
curved surfaces? I know I ca...
331
Views
by
JIMVANDRAGT
743
Views
| Good Afternoon, Is there a call available to determine if the current
ProE model needs to be saved? ...
743
Views
All, Is it possible to retrieve the array of widestring command lines
from a custom auxiliary NC seq...
476
Views
by
StevenDunell
710
Views
| Hello everyone, i'm very new to Mechanica and need a little help. I'm
trying to understand the SI un...
710
Views
Does anyone have a proe 3d model of an armillary sundial. Not for
commercial use. Thanks Steve
295
Views
Are there any human models out there I can download and use? I'm not
cheap but the boss is, so free ...
318
Views
by
GavinBRumble
1 Reply
531
Views
| Has anybody looked into using the new online Sun Grid supercomputer for
Mechanica studies? At $1 per...
1 Reply
531
Views
Does anyone know to disable pre-selection highlighting in WF2.0? I want
my WF session to start witho...
320
Views
I know this was answered last week but I failed to copy it and lost the
answer. How do you convert a...
321
Views
Thanks, taking out all my radii did the trick.
281
Views
The consensus of those who responded was that the 'prehighlight no'
setting does kill the 'smart' fi...
324
Views
I have an off the wall question. I need to add a clearance hole just
large enough for a #2 Phillips ...
365
Views
Two tall trees, a birch and a beech, are growing in the woods. A small
tree begins to grow between t...
441
Views
Thanks for all who responded, although the email attachments where
blocked I forwarded them to my ad...
303
Views
Any one know where I can find a good materials library file, I need to
set one up here. Robert Parso...
354
Views
1 Reply
13659
Views
| PTC tech support says "Dynamic Random" analyses require PSD input to be
in the units of acceleration...
1 Reply
13659
Views
by
billfish
1 Reply
761
Views
| Hello Gurus, I hope that someone has a formula (to share) for
calculating how many (circular x-secti...
1 Reply
761
Views
Greetings, In Pro/I TK 3.x, what are the criteria for identifying a
ghost or incomplete object? I do...
391
Views
Hello, following is my grey.dlg , I'm using it for shaded screenshots
with white background. V4.0 # ...
303
Views
The PTC default lighting tends to wash out detail and makes for a very
"flat" image. I load my own s...
343
Views
by
TerryJohnson
283
Views
| Our next meeting will be at Tarrant County Community College, South
Campus, Rm STEC1134 in the Techn...
283
Views
Dear All, Could you let me know what RBG setting did you use for
stainless steel and titanium? Thank...
616
Views
387
Views
1 Reply
481
Views
| Gotta love our government......... "If money is not a factor" Paul
Edwards
1 Reply
481
Views
| Subject | Author |
