how to make model dimensions larger
SYNDAKIT
this should be an easy one for all you guys out there.
How do I make these dimensions larger?
Doesn't the hidden config control this?
Found it - again. http://www.synthx.com/tom/sy_tip_0307.htm
TEXT_HEIGHT_FACTOR 40
7 REPLIES 7
This might help read the text better:
enable_transparent_text_bg *yes/no
David, that is not doing anything for me in Creo 2.0... at least not in session.
edit: I take it back... it takes affect after a while
AndyHermanson
(To:dschenken)
Isnt this controlled in the .dtl file in the part or assembly? I dont have access to Creo right now to look but i think you can control it there or in the properties menu for the dims.
You might add an addendum to your support case
It wouldn't be the first time CS was up for learning something new... or old... whatever.
The only response to that is "WOW!"
Why bother implementing a good idea.
SYNDAKIT
(To:SYNDAKIT)
I can confirm that it does work. I'm using Creo 3.0 M020.
Although you can't search for it, you can enter it manually into the configuration options.
I love this group.
Thanks to all of you that help.
-Joe
