publish drw and asm
Dmi3U
publish drw and asm
Hi all!
is there a way to sepparate drw publishing from asm/prt? Our cadworker gets overwhelmed with cad doc publishing, so thinking of different ways to make use of multiple cadworkers.
Thank you,
D
BenLoosli
(To:Dmi3U)
Setup multiple CADworkers with multiple queues.
I used to have 2 CADworkers with 4 queues, but since the upgrade to WC10, I have only put 1 CADworker back online.
Dmi3U
(To:Dmi3U)
In Reply to Dmitry Ushamirsky:
Hi all!
Thank you,
D
So, the reason i need to separate drw from asm and prt is that we are publishing drw to pdf using Adobe LiveCycle. If I just create another cadworker, than I will need to buy another license of LiveCycle. Trying to avoid doing this.
