I´m using Creo from a month ago, at the beginning it works O.K, now, I have to repaint the screen over and over again because the dimensions and things like that, stays in the graphic windows,
Have you updated your graphics driver between the time it worked and when it stopped working properly?
Unfortunately no, how can I do that?
It is a good thing that you didn't. Normally that would be the 1st culprit.
If you have an academic version of Creo, please use the academic support page
PTC Academic Program | Academic Technical Support | PTC
If you have a full license and are still under maintenance, please file a support case.
