save-as with update parent
wfalco
All,
Anyone have a "how to" for:
Workspace save-as with update parent. (How to use the "update parent"
ability?)
WayneF
11 REPLIES 11
RandyJones
20-Turquoise
(To:wfalco)
On 06/06/13 10:29, wayne falco wrote:
> All,
> ability?)
There is not really very much "how to" for this. Either you select the the parent assembly for
updating or you don't. The parent assembly needs to be checked out (or a new object) in order to be
eligible for updating.
> WayneF
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
wfalco
(To:wfalco)
I guess I was looking for a decent example on the steps.
kdirth
(To:wfalco)
First the item being copied and the parent assembly need to be uploaded or unmodified and the parent assembly needs to be checked out.
Check the item being copied and select File/Save As
Update name of copy and select next.
Check the assembly to replace the item in and select Use Copy.
Select Finish.
If the parent assembly is "Struck Through", it is ineligible for some reason.  Hover mouse over red "i" to see reason, then cancel copy, fix issue, and start over.
wfalco
(To:wfalco)
A fellow worker uses this when he forgets to include an item in a save
as. He's not much on documenting how he does it. So - I am reaching.
dschenken
(To:wfalco)
The Windchill local client automatically prompts for the substitutions desired as soon as you do a Workspace Save-As to search for/select the target assembly (ies) and the target assembly(ies) need to be in the Workspace and be checked-out.
I think the lack of a video/all steps is that it is about 50 times more effort to create that tutorial than for you to try it.
Wassa matta John you scaid o'sumetine, scaid??
YOU BIG DUMMY
DeanLong
(To:wfalco)
Wayne Falco?     Wayne Falco?     Wow...Wayne Falco!!
Hey Dean. How's things?
DeanLong
(To:wfalco)
Still making little rocks from big rocks. distress.jpgYou know, I am retired but I still have to go to work every day!
wfalco
(To:wfalco)
Ha! I seem to be in that same zone.
