First the item being copied and the parent assembly need to be uploaded or unmodified and the parent assembly needs to be checked out.
Check the item being copied and select File/Save As
Update name of copy and select next.
Check the assembly to replace the item in and select Use Copy.
Select Finish.
If the parent assembly is "Struck Through", it is ineligible for some reason. Hover mouse over red "i" to see reason, then cancel copy, fix issue, and start over.
The Windchill local client automatically prompts for the substitutions desired as soon as you do a Workspace Save-As to search for/select the target assembly (ies) and the target assembly(ies) need to be in the Workspace and be checked-out.
I think the lack of a video/all steps is that it is about 50 times more effort to create that tutorial than for you to try it.
Wassa matta John you scaid o'sumetine, scaid??
YOU BIG DUMMY
Wayne Falco? Wayne Falco? Wow...Wayne Falco!! ![]()
Hey Dean. How's things?
Still making little rocks from big rocks.
You know, I am retired but I still have to go to work every day!
Ha! I seem to be in that same zone.
