Check out this video on Creo Additive MFG from PTC Application Engineers
Presenters: Lino Tozzi (Solution Consultant, Fellow) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: November 16, 2023
To dive deeper into the subject, check out Creo Additive MFG.
WEBCAST Q&A
Question from Ryan: Do you support/generate organic supports?
Answer: The supports are what comes from Materialize Magics
WEBCAST Q&A
Question from Anonymous: In order to minimize support structure further, is the any command which suggest to modify original geometry thereby reducing support structure?
Answer: The build actually add parameters that could be optimized by changing geometry. This could be done with Behavioral Modeling.
