Creo Additive MFG Tips & Techniques Session Recording (East Coast)
No ratings
Check out this video on Creo Additive MFG from PTC Application Engineers
Presenters: Lino Tozzi (Solution Consultant, Fellow) and Ryan Butcher (Solution Consultant, Fellow)
Original Date Presented: November 16, 2023
To dive deeper into the subject, check out Creo Additive MFG.
Comments
WEBCAST Q&A
Question from Ryan:  Do you support/generate organic supports?
Answer:  The supports are what comes from Materialize Magics
WEBCAST Q&A
Question from Anonymous:  In order to minimize support structure further, is the any command which suggest to modify original geometry thereby reducing support structure?
Answer:  The build actually add parameters that could be optimized by changing geometry.  This could be done with Behavioral Modeling.
Version history
Last update:
‎Jan 19, 2024 04:05 PM
Updated by:
Labels (1)
Contributors
