Creo Ansys Tips n' Techniques
No ratings
Check out this video on Creo Ansys from PTC Application Engineers. Presenters: Lino Tozzi (Technical Specialist, Fellow) & Tom Quaglia (Creo Segment Sales).
Comments
WEBCAST Q&A
Question from Anand:  Is it possible to check the failure location while creating mesh?
Answer:  The high stresses are a result of the mesh.  When running once with a mesh density, you would change the mesh density (like Lino is doing now) in the are of high stress.
WEBCAST Q&A
Question from Brian:  Is there a way to check the quality of the mesh?
Answer:  Mesh size and aspect ratio is defined by the user.  The mesh will be created within those bounds.
Question from Brian:  Can linearized stress be calculated in post-processing?
Answer:  Not at this time.
WEBCAST Q&A
Question from Rajesh:  Can we change mesh size as desired?
Answer:  Yes, the mesh can be modified locally and/or globally.
WEBCAST Q&A
Question from Tim:  Can you use a temperature-dependent materials and thermal loads in the structural solver?
Answer:  The material properties are constant and do not change with temperature.  Creo Advanced Simulation can use Thermal loads in the Structural solver (MechT).  Not Creo Ansys just yet.
Version history
Last update:
‎Sep 28, 2022 09:01 AM
Updated by:
Labels (2)
Contributors
