Check out this video on Creo Options Modeler from PTC Application Engineers.
Presenters: Jason Petersen (Technical Specialist, Principal) & Tom Quaglia (Creo Segment Sales).
WEBCAST Q&A
Question from Anonymous: Can the "Design Exploration" module be utilized with a Configurable Assembly?
Answer: Design Exploration is not available while working with Options Modeler.
WEBCAST Q&A
Question from Dean: Can you create a CAD-driven BON off of the variant? I want to place a BOM on the drawing using the CAD model with a table of repeat regions.
Answer: Yes, you can do that with the Variant product that is built as output from the Configurable product.
WEBCAST Q&A
Question from Gordon: Is there a way to save a specific configuration as a standard (non-configurable) assembly?
Answer: In the "Variant Builder" choose "Create Product Variant". This creates a standard (non-configurable) assembly.
Question from Gordon: In the past, we attempted to use configurable products while designing the product. This generated a mess. It might be important to have the product fully designed before configuring it.
Answer: That is correct. You should have all of your Options and Choices designed in your Configurable product first.
WEBCAST Q&A
Question from Ian: At some point, can you re-show the clicks that led to the save as configurable...dialogue box?
Answer: You choose File/Save As/Configurable Product.
WEBCAST Q&A
Question from Michael: As Options Modeler is a topic today, are you planning to make a session regarding Options & Variants soon?
Answer: Yes, we will be doing that topic in the T&T sessions for PLM in the next couple of months.
