I recently update to Creo 8.0.2. In previuos versions, it was possible to have the edge of the planes of two different color (one for the positive side, one for the negative side).
In Creo 8 now only the surface of the planes is colored (one for positive, one for negative) but not the edge fo the planes. The edge are the same color for both sides.
How can I set this in Creo 8?
Thank you.
@cgorni thank you very much! You are the best!
