Multibody – Another look at patterning bodies with Creo 11 and higher
- July 28, 2025
- 4 replies
- 12882 views
Welcome to Blog Post #21 in Our Multibody Series!
In today’s post, we’re diving into a powerful new capability introduced in Creo 11—the ability to reference an existing point/coordinate system based pattern in a geometry pattern of type "point" pattern. This enhancement can significantly streamline your workflow, especially when working with complex body patterns.
To get started, check out the What’s New video linked below. The first section highlights the benefits of the new “From Pattern” option in point patterns, which helps accelerate regeneration using the “Identical” or “Flexible” regeneration modes. Around the 50-second mark, the video also demonstrates some useful body patterning techniques.
While the video covers the basics, here are a few key tips and tricks to help you get the most out of this feature:
- Patterning Bodies with Coordinate Systems
Use a pattern of coordinate systems to define both the position and orientation of each body pattern member precisely. - Using Curves for Placement of Coordinate Systems
If your bodies lie on a plane, consider sketching a curve with points that define their future locations. Then, replicate a coordinate system along that curve using the “Follow the Curve” option. This approach makes it easy to align all coordinate systems—for example, pointing them inward. - Leverage the “From Pattern” Option
When creating a Point Pattern, use the new “From Pattern” option to inherit the structure of an existing pattern. - Set the Alternate Origin
When defining the body pattern, be sure to select the first coordinate system as the alternate origin for the lead pattern member. This step ensures the correct orientation relationship is maintained during replication. - Merging Patterned Bodies
When merging patterned bodies, always select the body pattern feature in the Modifying Bodies collector of the Boolean Merge feature. This ensures the model updates parametrically if the number of bodies in the pattern changes.
Thanks for reading. I hope it was informative.
If you liked it, give it a Kudo.
Back to Creo Multibody Home: Start Here!
Enjoy!....Martin
