Tool Design & Mold Analysis Tips & Techniques Session recording (East Coast)
No ratings
Check out this video on Tool Design & Mold Analysis  from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist), Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales )
Original Date Presented: September 16th 2021.
Link to all Creo Tips and Technique Recordings
Comments
Webcast Q&A
Question from AlHow do you model/work with a mold that has a multiple core pins that creates cavities in the part?
Answer:  You would create multiple volumes and extract them from the overall volume.
Webcast Q&A
Question from Anonymous:  When are the menus going to be updated?
Answer:  Good question!  We left a few old school menus for nostalgic purposes 😉
Webcast Q&A
Question from ChrisThere are complex parts that need 3 mold parts.  Can you show us an example?
Answer:  There can be hundreds of parts to the mold if desired.  You do this by creating multiple mold volumes/parting surfaces.
Webcast Q&A
Question from ClaudiuIs Creo able to have analyze feature find a minimum distance between a Runner Mold Feature and a Cut or Hole?  I've seen that there is an analyze feature (close proximity) between a Water Line and a hole, but I would like to be sure the hole is not closed to a runner.
Answer:  You could do a minimum 3D thickness check.  Aside from that, you have full measurement/clearance checking.
Webcast Q&A
Question from KunalHow can we create undercuts?
Answer:  Same as any other parting surface but the undercut will show up as a potential issue.  You can leave it as is if you wish.
Webcast Q&A
Question from MichaelIs Creo able to determine the flow of your water lines and advise what your Reynolds number would be?
Answer:  Yes, with Creo Flow Analysis.
Webcast Q&A
Question from PaulWith glass polyester, there is part shrinkage.  How do you accommodate that?
Answer:  Shrinkage can be added isotropic or anisotropic.
Being new(ish) to Creo we struggle with this as its so out dated compared to the rest of the software
Version history
Last update:
‎Sep 16, 2021 04:42 PM
Updated by:
Labels (2)
