Check out this video on What's New in Creo 8 & 9 from PTC Application Engineers
Presenters: Lee Goodwin (Solution Consulting, Principal)
Webcast Q&A
Question from Andrew: When it becomes inseparable does the model become more light weight for rendering purposes?
Answer: The rendering is geometry based. The geometry is not changing so rendering should be no different.
Question from Andrew: Can you then re-run the generation to make the associated keep out after removing the beam?
Answer: No, this is after the fact. It does not stay removed when you re-lattice.
Question from Andrew: We call out surface finish via note and leader with colored faces. Is the new call out able to reflect the faces it references?
Answer: Yes, this was update in Creo 7.0. Divide in 9.0 if you only want parts.
Question from Andrew: Is that only for MDB?
Answer: Divide surface is an OOTB 3D function.
Webcast Q&A
Question from Julio: Are the some improvements for drawings?
Answer: Yes, sketching and symbols.
Webcast Q&A
Question from Kathryn: Is there a way to see the amount of interference?
Answer: In part mode the volume of interference region is displayed.
Webcast Q&A
Question from Roger: Is exporting inseparable assemblies a planned feature?
Answer: No, just for imported models into Creo.
Webcast Q&A
Question from Vasi: In a drawing, BOM table is still working with the inseparable assemblies?
Answer: Yes, there is a config option.
