AFX / EFX Embedded vs seperate Install?
neluyt1
Hi All
  1. Embedded Install - EFX is an option when installing Proe/Creo, it installs into the Creo installation directory, and you activate it using the config option EFX_ENABLED YES (AFX_ENABLED YES for latest versons....).
  2. You can download the EFX7.0 M010 installation and install into a seperate location. You add a Protk.dat entry into your config file pointing to the efx/bin folder and the relevant toolkit application file that is supported with your version of ProE.
So lets assume you have an EFX license, both these methods gets you into a position to run EFX.
With method 2, you have addituional admin to keep the seperate install up to date, however if you just update Creo to a later build, you will not lose your customizations because of the seperate install.
My question is which is best?
PS: What's with the undercover, secret squirrel renaming of EFX to AFX without telling anybody...? I only found out because with the latest Creo, my EFX_ENABLED config option didnt work anymore... because PTC renamed the application... and I was unable to smell the change on the wind in time...
lococnc
(To:neluyt1)
Method 1 is correct way to install.
You then point AFX to your customized libraries.
