Any toolkit API to get the item Quantity.(i.e rpt.qty)
  • June 17, 2015
  • 1182 views
Best answer by mender
No, I'm afraid there's no Toolkit APIs for repeat regions and their records.  You can take the assembly, traverse the components, and calculate the quantities.  You might even be able to read the text from the table and interpret it as needed, but I imagine going from the assembly would be better.
mender12-AmethystAnswer
mwaghmode1-VisitorAuthor
Thanks Matthew,
Yes i thought same approach to find the item quantity in assembly.
I would be good if some API will do the same job.
//Manoj
