Hi everyone,
Is it possible to model a cylinder via VB API ?
API to create new feature is only available in Protoolkit and not in VBA.
But you can create code using UDF. In this case you need to define the UDF placements.
I don't have much experience with creo, could you tell me how to proceed?
in the examples provided with the creo installation, I found this function, which should create some spheres:
Public Function createNodeUDFInPart(ByVal placementModel As IpfcSolid, _
ByVal csysName As String, _
ByVal diameter As Double) _
As IpfcFeatureGroup
Dim csys As IpfcCoordSystem = Nothing
Dim cSystems As IpfcModelItems
Dim i As Integer
Dim udfInstructions As IpfcUDFCustomCreateInstructions
Dim csysSelection As IpfcSelection
Dim csysReference As IpfcUDFReference
Dim references As CpfcUDFReferences
Dim variantDims As IpfcUDFVariantDimension
Dim variantVals As IpfcUDFVariantValues
Dim group As IpfcFeatureGroup
Try
cSystems = placementModel.ListItems(EpfcModelItemType.EpfcITEM_COORD_SYS)
For i = 0 To cSystems.Count - 1
If (cSystems.Item(i).GetName.ToString = csysName) Then
csys = cSystems.Item(i)
Exit For
End If
Next
If csys Is Nothing Then
Throw New Exception("Coordinate System not found in current Solid")
End If
'Instructions for UDF creation
udfInstructions = (New CCpfcUDFCustomCreateInstructions).Create("node")
'Make non variant dimensions blank to disable their display
udfInstructions.DimDisplayType = EpfcUDFDimensionDisplayType.EpfcUDFDISPLAY_BLANK
'Initialize the UDF reference and assign it to the instructions.
'The string argument is the reference prompt for the particular
'reference.
csysSelection = (New CMpfcSelect).CreateModelItemSelection(csys, Nothing)
csysSelection.Highlight(EpfcStdColor.EpfcCOLOR_SELECTED)
csysReference = (New CCpfcUDFReference).Create("REF_CSYS", csysSelection)
references = New CpfcUDFReferences
references.Set(0, csysReference)
udfInstructions.References = references
'Initialize the variant dimension and assign it to the instructions.
'The string argument is the dimension symbol for the variant dimension.
variantDims = (New CCpfcUDFVariantDimension).Create("d11", diameter)
variantVals = New CpfcUDFVariantValues
variantVals.Set(0, variantDims)
udfInstructions.VariantValues = variantVals
'We need the placement model for the UDF for the call to
'CreateUDFGroup(). If you were placing the UDF in a model other than
'the owner of the coordinate system, the placement would need to be
'provided separately.
group = placementModel.CreateUDFGroup(udfInstructions)
Return group
Catch ex As Exception
MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
Return Nothing
End Try
End Function
The problem is that when I invoke it, the instruction
placementModel.CreateUDFGroup (udfInstructions)
creates an exception and I can't understand why.
Can anyone help me?
