Hello everyone.
I trying to put some dimensions automatically on a 2D drawing. I don't want that this dimensions cames from the 3D Model. I want to create directly on the drawing.
For that, i need to know some entities of the drawing, so i can give the attachments to the function ProDrawingDimCreate().
I need to know if you guys, know some way to visit entities like ProPoints or ProEdges of a specific ProView.
What do you suggest?
Many Thanks.
I did a similar project years ago. It was a CAD/CAM automation system written in ToolKit and API (in C#).
Auto-dimension was included for the key feature location, implemented in C#.
Here is My some samples code in C#.
Hope this help
public bool CreateAxisPosiontDimension(TaskData task,string CsysName, string ViewName, string ParamName, string ParamValue,double PlateWidth)
IpfcSelection csysSelection,PointSelection;
IpfcModelItem item;
IpfcView2D selView=null;
IpfcView2Ds views;
CpfcPoint3D SelPosition;
IpfcModelItems Points;
CpfcPoint3D csysPosition,pointPisition;
IpfcTransform3D viewTransform;
CpfcVector2D Csys3DPosition,dimPosition;
IpfcOutline3D outline;
CpfcDimensionSenses senses;
IpfcPointDimensionSense sense1,sense2;
CpfcSelections attachments;
IpfcDrawingDimCreateInstructions createInstructions;
IpfcDrawingDimensionShowInstructions showInstructions;
IpfcDimension2D dimension;
IpfcDimension2D hBaseLine=null,vBaseLine=null ;
List<CpfcPoint3D> AllPoints = new List<CpfcPoint3D>();
List<IpfcModelItem> AllValidAxis= new List<IpfcModelItem>();
Mylog.AddLog("Start to Generate Position Dimension:");
try
drawingMdl = task.drawingModel;
OpenDrawing();
((IpfcSheetOwner)drawing).CurrentSheetNumber = 1;
item = ((IpfcModelItemOwner)task.referenceModel ).GetItemByName((int)EpfcModelItemType.EpfcITEM_COORD_SYS, CsysName);
views = ((IpfcModel2D)drawing).List2DViews();
for (int i = 0; i < views.Count; i++)
if (views[i].Name == ViewName)
selView = views[i];
break;
if (selView == null)
Mylog.AddLog("Can't Find View with name of " + ViewName);
return false;
double scale=selView.Scale;
selView.Scale = (24.0 / PlateWidth) * scale;
csysSelection = (new CMpfcSelect()).CreateModelItemSelection(item, null);
csysSelection.set_SelView2D(selView);
SelPosition = csysSelection.Point;
csysPosition = SelPosition;
viewTransform = selView.GetTransform();
csysPosition = viewTransform.TransformPoint(csysPosition);
Csys3DPosition = new CpfcVector2D();
Csys3DPosition.Set(0, csysPosition[0]);
Csys3DPosition.Set(1, csysPosition[1]);
outline = selView.Outline;
senses = new CpfcDimensionSenses();
attachments = new CpfcSelections();
sense1 = (new CCpfcPointDimensionSense()).Create((int)EpfcDimensionPointType.EpfcDIMPOINT_CENTER);
sense2 = (new CCpfcPointDimensionSense()).Create((int)EpfcDimensionPointType.EpfcDIMPOINT_CENTER);
senses.Set(0, sense1);
senses.Set(1, sense2);
Points = ((IpfcModelItemOwner)task.referenceModel ).ListItems((int)EpfcModelItemType.EpfcITEM_POINT);
for (int c = 0; c < Points.Count; c++)
PointSelection = (new CMpfcSelect()).CreateModelItemSelection(Points[c] , null);
PointSelection.set_SelView2D(selView);
pointPisition = viewTransform.TransformPoint(((IpfcPoint)Points[c]).Point);
attachments.Set(0, PointSelection);
attachments.Set(1, csysSelection);
dimPosition = new CpfcVector2D();
if(csysPosition[0]>pointPisition[0])
dimPosition.Set(0, outline[0][0] - 10);
else
dimPosition.Set(0, outline[1][0] + 10);
dimPosition.Set(1, (csysPosition[1] + pointPisition[1]) / 2);
createInstructions = (new CCpfcDrawingDimCreateInstructions()).Create(attachments, senses, dimPosition, (int)EpfcOrientationHint.EpfcORIENTHINT_VERTICAL);
dimension = ((IpfcModel2D)drawing).CreateDrawingDimension(createInstructions);
showInstructions = ((new CCpfcDrawingDimensionShowInstructions()).Create(selView, null));
((IpfcBaseDimension)dimension).Show(showInstructions);
if (c == 0)
vBaseLine = dimension.ConvertToBaseline(Csys3DPosition);
else
dimension.ConvertToOrdinate(vBaseLine);
createInstructions.OrientationHint = (int)EpfcOrientationHint.EpfcORIENTHINT_HORIZONTAL;
dimPosition.Set(0, (csysPosition[0] + pointPisition[0]) / 2);
if (csysPosition[1] < pointPisition[1])
dimPosition.Set(1, outline[1][1] +10);
else
dimPosition.Set(1, outline[0][1] - 10);
createInstructions.TextLocation = dimPosition;
if (c == 0)
hBaseLine = dimension.ConvertToBaseline(Csys3DPosition);
else
dimension.ConvertToOrdinate(hBaseLine);
Mylog.AddLog("Dimension for part " + task.sJobCode + " has been done.");
catch (Exception e)
Mylog.AddLog(" Faile to Generate dimension for Part " + task.sJobCode + "\n"+e.Message);
drawingMdl.Save();
if (DWGWindow != null)
DWGWindow.Close();
return true;
Many thanks for your help.
I will check your solution and use it in my problem.
Best regards.
