Can I set a specific lifetime when deploying a DLL?
Or can I set up additional licenses for C language programs?
If possible, please explain what you need to do.
Thanks a good weekend
Expected this question as well.
Implemented a scenario with below details:
-HIH
Ketan
It's possible. We have achieved the same.
Below should be done in user_initialize() :
HIH
Ketan
It is a very good offer!
But the system time can be changeable
The above conditions are not particularly attractive if you change the system time.
Is there any other way?
For example, can I see that the system time has changed?
-HIH
Ketan
It's fun!
I saved the time when the toolkit was run as a binary file to a * .dat file.
Then compare the time stored in the file with the current time.
If the current time is after the saved time, the toolkit exits.
Thank you.
