Change varied Items VB API
Civodul
Does anybody know how to change new value of varied items with CREO 7 VB API.
Regards
Ludovic Besse
Civodul
(To:YaroslavSin)
It's true.
Thanks for your time
In VB API this is not possible.
You can use a workaround:
1) In assemble create a relation PARTVARPARAM:CID_XX = ASMPARAM
where
PARTVARPARAM - variable parameter in the part
CID_XX - XX is a ID of the part component in the assembly
ASMPARAM - assembly parameter
2) Using VB API change the value of the asm parameter "ASMPARAM"
Civodul
(To:YaroslavSin)
I've already tried this solution, the problem is that the native assembly is also modified.
You are right.
But I think, that by changing a variable parameter of the component will change the assembly too.
Is it not true?
Civodul
(To:YaroslavSin)
It's true.
