Checking repeat region filter with toolkit
AlexCote
so I already have a toolkit that iterate trough a drawing tables and check for table with repeat region.
What I would like to do is that while going through the tables, find the one that has a certain filter.
When in CREO I go to the Repeat Region Menu then select Filter and Show, I can see this as my filter: &mdl.param.name == docid
The table is always a single cell table containing my document number and would like to get it.
Anyone knows how to achieve this?
I tried with this method:
				p_CurrTbl = &MyTablesCollection[i];
				ProWstring **FilterText;
				error = ProDwgtableCelltextGet(p_CurrTbl, 1, 1, ProParamMode(2), FilterText);
				if (error == PRO_TK_NO_ERROR) {
					//Convert the ProWstring text to char
					char* MyTmpChar = NULL;
					char NewTmpTxt[50];
					MyTmpChar = (char*)calloc(sizeof(char), wcslen(**FilterText) * 3);
					char* tmp_chr = ProWstringToString(MyTmpChar, **FilterText);
					if (sizeof(NewTmpTxt) < strlen(tmp_chr) + 1) {
						goto _END;
					strncpy(NewTmpTxt, tmp_chr, sizeof(NewTmpTxt));
					ShowMessage(" NewTmpTxt : %s", NewTmpTxt);
But this only returns this:
AlexCote
(To:AlexCote)
I finally ask PTC about this, and they have confirm me that this is not supported by the Toolkit API.
AlexCote
(To:AlexCote)
FV
(To:AlexCote)
This is not an answer to the question but rather a warning for people who may copy/paste the code below.
ProDwgtableCelltextGet call has wrong arguments (in bold) ...
				if (error == PRO_TK_NO_ERROR) {...}
 The correct call is:
ProWstring *wstr_arr = NULL;
ProParamMode pmode = PRODWGTABLE_FULL; // or PRODWGTABLE_NORMAL
error = ProDwgtableCelltextGet(p_CurrTbl, 1, 1, pmode, &wstr_arr);
if (error != PRO_TK_NO_ERROR) {
return PRO_TK_GENERAL_ERROR;
// do something with text ...
} ProWstringproarrayFree(wstr_arr);
