Could we use JavaFX with Creo Java Toolkit
RJ_11007702
We are trying to develop a Creo Java Toolkit based application in synch mode (going by the recommendation from PTC) . We would like to use JavaFX for the UI .
We see some old articles mentioning the issues related to using JavaFX in Creo Java Toolkit app and like to understand if there are folks who have used it successfully and any guidelines or recommendations to follow to do so.
@Florent_Colab @GS_14113977
I do not know why JavaFX would not work. Look at the parameter editor in the jlink jlink_param examples. This uses swing however I would think JavaFX would also work.
