Create Component Interface feature using Creo Toolkit
PARTHIBAN_K
How to create the component interface using Creo Toolkit in part model?
Parthiban Kannan
href="https://www.linkedin.com/in/parthiban-kannan/" target="_blank"
Found the solution for it. Below is element tree structure for component interface
	static ElemTreeData tree[] = {
		{0, PRO_E_FEATURE_TREE, {(ProValueDataType)-1}},
		{1, PRO_E_FEATURE_TYPE, {PRO_VALUE_TYPE_INT, {PRO_FEAT_COMP_INTERFACE}}},
		{1, PRO_E_COMP_INTERFACE_NAME, {PRO_VALUE_TYPE_WSTRING}},
		{1, PRO_E_COMPONENT_INTERFACE_SETS, {(ProValueDataType)-1}},
		{1, PRO_E_COMP_INTERFACE_CONSTRAINTS, {(ProValueDataType)-1}},
		{2, PRO_E_COMP_INTERFACE_CONSTRAINT, {(ProValueDataType)-1}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_TYPE, {PRO_VALUE_TYPE_INT, {4}}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_REF, {PRO_VALUE_TYPE_SELECTION}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_REF_OFFSET, {PRO_VALUE_TYPE_DOUBLE, {0.0}}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_RULE, {PRO_VALUE_TYPE_INT, {0}}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_SET_ID, {PRO_VALUE_TYPE_INT, {-1}}},
		{3, PRO_E_COMP_INTERFACE_CONSTR_ATTR, {PRO_VALUE_TYPE_INT, {0}}},
		{1, PRO_E_COMP_INTERFACE_RULE, {(ProValueDataType)-1}},
		{1, PRO_E_COMP_INTERFACE_RECEIVE_TYPE, {PRO_VALUE_TYPE_INT, {0}}},
		{1, PRO_E_COMP_INTERFACE_TYPE, {PRO_VALUE_TYPE_INT, {5200}}},
		{1, PRO_E_COMP_INTERFACE_DEFAULT, {PRO_VALUE_TYPE_INT, {0}}},
		{1, PRO_E_COMP_INTERFACE_DESCRIPTION, {PRO_VALUE_TYPE_WSTRING}}
Parthiban Kannan
Parthiban Kannan
