Create a progress circle using Creo UI editor
RJ_11007702
I see there is a Progress bar component in Creo UI editor.
1. Is it possible to have something like a progress circle in Creo UI editor?
2. Or a custom gif that we could display to accomplish showing an in-progress operation?
cc @GS_14113977
Looks like there is a progress bar component. I have never used it before. (The screen shot is from version 7)
6 REPLIES 6
Thanks @MikePhillips .
 Apologies if I was not clear, what I meant was, I see the Progress bar component but is it possible to use a circle to show the progress instead of a 'bar' or anything custom for that matter.
Sorry. I did not read your post very well at all! That is my mistake. 🤣
I would think you could utilize a Drawing Area. You could then loop thru a serious of images that create the illusion of an animated circle progress. Or draw a progress image.
No worries @MikePhillips !
Thanks for the workaround. We will consider this to see if this fits into our requirement. Thanks again!
Hi @RJ_11007702,
Anurag
RJ_11007702
(To:anursingh)
Thank for the follow up @anursingh !
The solution suggested by @MikePhillips seems the only way ahead. Though in the interest of time (and keeping in mind the maintenance requirement of a custom solution),  we have slightly modified our requirements .
