Creating installer for JLink development
SD_10158207
7-Bedrock
Hello Developers,
Need your input on developing and sharing the installers to end users for the development done using JLink.
Also I want to keep the installer specific to Creo Version.
Right now I have done with the development of Creo Automation using JLink. Looking for the way to share a simple installation file rather a traditional protk.dat approach.
Waiting for your inputs
Thanks in advance
remy
(To:SD_10158207)
You're done with the creation and testing of your JOTK Free application and you need to design and think ahead of the deployment of the app in your organization.
One of your constraints is to stick to a specific version of Creo and another one is to make the installation less fussy than the flat files to copy.
Given your constraints (checking and simpliflying), from my experience as a software developer (before joining PTC), to create a portable exe file that performs verifications and search the proper folders and paste the proper file to given directories, you need a packaging software.
It's basically an application that enables to design an installation CD.
The last one I used was InstallShield and it is not free. Yet again, it is a personal recommendation and PTC cannot be held accountable for this proposition.
Maybe some alternative exists that other contributors can share.
Also how many seats do you need to install the application on? The workload is different if this is a matter of dozens or hundreds.
sjuraj
(To:SD_10158207)
I use this https://jrsoftware.org/isinfo.php
You need to put your protk.dat to program data folder https://community.ptc.com/t5/Customization/Is-their-any-way-to-Run-creo-C-ToolKit-plugin-without-loading/td-p/690393
while instlling you can create multiple folders (for multiple versions of creo)
