I'm looking for some advice. It seems that ProDrawingFromTemplateCreate() does not allow for the use of a simplified representation to be utilized to create a new drawing (resulting in the drawing being created with 'master'). I want to avoid loading 'master' into a newly created drawing.
How are others working around this limitation?
I'm considering this approach:
- Supply ProDrawingFromTemplateCreate() with a temporary empty assembly model to create drawing
- Use ProDrawingAsmsimprepAdd() to add a preselected simp rep to the drawing
- Delete the temporary assembly from the drawing.
Thoughts?
In this case just copy your template and rename it by yourself. If you do the rename in Creo make sure to be not in the template folder. Else you will/may rename your template 😉
The template path can be extracted from your configuration option with Toolkit as well. If you need this at all.
After rename and open, or vice versa, just add your simplified model to the renamed drawing.
I think this should work.
With other word, you may need to implement ProDrawingFromTemplateCreate by your own.
Do you want to use predefined Views (front, top, …) from your Drawing Template?
No, I don't want to use predefined views. I just want to start with an empty drawing.
Why didn't I think of that!? 🤔
So simple. I will give it a try. Thank you!
Hi @MikePhillips,
Anurag
