We’re aware of an issue preventing community login. Our team is actively working on a fix and we’ll share updates as soon as possible.
Hello Olaf,
we have successfully installed Creo Parametric 2.0 M070 with the new silent install mechanism, which you describe, on about 40-50 PCs (windows 7 64-bit)so far.
We use the same XML-files as you:
pma.p.xml creobase.p.xml and sim.p.xml
from a successful non-silent installation and we even did some changes in the XML-files maually (changed destination path or changed some modules from "no" to "yes")
But on 2-3 occassions we observed the same incomplete installation as you did.
The incomplete installations were easy to detect, because the parametric.exe file was mising and so Creo could not be launched at all on these PCs.
Unfortunately the silent installation isso silent that you don't see, what it's actually doing.
So I also have not found a reason for this so far. The only solution is to re-run the setup. However I'm currently trying to convince PTC techsupport and R&D to provide some kind of logging, which would deliver a protocol of the setup process.
I fear that this is unavailable in the current release of Creo 2.
As we are about to install Creo 2 M070 on ca. 500 PCs starting next week, I can only hope that the failure rate is not too big.
Best regards
Johannes
