Creo 2 Jlink App Help
  • August 16, 2012
  • 3 replies
  • 1011 views
I am trying to get a simple Jlink app working for Creo parametric 2.0 and I am failing miserably.
No matter what I seem to try I still can't get the app to load in Creo 2.0. I don't know if it is my Jlink program or my machine.
Here are my files. Any help would be appreciated.
myApps.java File
Brian,
The java classpath cannot be set from the protk.dat file.
java_app_classpath J:/myappsCreo/.
Set it with config.pro option add_java_class_path or set it from your .psf or .bat file that launches Creo.
/Bjarne
Brian -
Everything you have there is correct, and it works on my machine (Bjarne is incorrect about the java_app_classpath statement - all my apps are set up that way and work fine). Check which java compiler you are using - by default Creo uses JRE 6, if you are using JDK 7 it will not work (unless you tell Creo to use JRE 7 through config.pro options). Also be sure if you have your CLASSPATH variable set to point to the pfc.jar file that it is the one in the Creo 2 installation, and not from a previous version.
Josh
In Reply to Brian York:
myApps.java File
Josh, thank you for the correction.
The java_app_classpath statement is optional, if set in another way.
I set it in the environment, as all my J-Link applications has the same classpath to the package folder. So a simple compare to my startup file showed the difference.
Sorry for the confusion.
/Bjarne
