I need to make a toolkit that reads the information in an Excel file.
I found some libraries in C that does that and I'm trying to use one of them. The one I'm trying to use is LIBXLS (https://github.com/libxls/libxls)
This library doesn't give the compiled resources, you have to compile by yourself. After some effort I could compile the library using cygwin (gcc, make, etc...).
At the end, I've got the .dll.a and the dll file and all the include files.
When I try to use the library in a C program and compile it using gcc, the library works fine.
But when I do the same thing to compile the toolkit, it doesn't work.
I tryed to use gcc to compile the toolkit, but I couldn't because it depends of some libraries and I'm getting an error when importing the visual studio library libcmt. But the library is not working when I compile the program using the default cl and link from nmake file.
What can I do to use the library inside the toolkit?
Or there is another option to read the excel file?
I'm using Creo 8.0.10
Hello, I'm not very sure, but I think the problem is mixing the gcc compiler with the PTC TOOLKIT libs, what does not work (different compiler suites).
If you manage to compile a callable "support"-DLL file (with gcc), this could be the interface to call from your MSVC compiled TOOLKIT DLL (load the "support"-DLL at runtime, call its functions). But this seems too complicated to me, given that you use different compiler suites.
Alternatives:
I recommend to use the native/original Excel API (COM/.NET).
Hi @AB_10248132
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Alternatives:
I really wasn't able to use the excel library.
Basically, I have to create my own library for this using Excel COM.
But it was not able to do in C, I had to change the project to C++.
Anyway, it was easier to start from scratch than making other libraries to work. But your suggestion to use COM saved me.
Thanks.
the first question is - are you sure you need xls reader and not a modern xlsx.
if xls is indeed is what you need, then download a zip file from github, uncompress, add an empty c or c++ project in your visual studio solution, use the same project settings as you had used for pro/toolkit projects, configure project's include path to point to the downloaded 'include' directory, add content of the downloaded 'src' directory to your project' 'source' folder (this is done in Visual Studio not in a file explorer), compile and link. If there are missing standard libraries - modify your project's linker->input configuration option to add them.
HIH
