Creo Weblink CREOJS updated notes question
AH_10565398
If my model changes and the note becomes unattached, my textline "&REF_DES:AT_CONN" calling a parameter changes to "***".
Once I go through and reattach all the leaders, I can run this function to update all the notes back to "&REF_DES:AT_CONN",  It only works if I've double clicked to edit the text before hand.
Has any one else had this issue?  Does Toolkit also have this issue, or is this solely a weblink problem?
function Notevisit() {
  if (pfcIsMozilla())
      netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
  var session = pfcGetProESession ();
  var model = session.CurrentModel;
  alert("STARTING NOTE REFRESH: PRESS 'OK', AND DO NOT TOUCH UNTIL 'DONE' IS DISPLAYED");
  model.Regenerate(void null);
  if (model == null)
      return;
  if (model.Type != pfcCreate("pfcModelType").MDL_DRAWING)
      return;
  var LABEL = "LABEL: &REF_DES:ATT_CONN";
  var name = String(LABEL)
  var LABEL2 = "LABEL: \*\*\*";
  var name2 = String(LABEL2)
  var notes = model.ListItems(pfcCreate("pfcModelItemType").ITEM_DTL_NOTE);
  for (var i = 0; i < notes.Count; i++) {
      if (notes.Item(i).GetDetailType() === pfcCreate("pfcDetailType").DETAIL_NOTE) {
          var item = notes.Item(i);
          if (item.Type == pfcCreate("pfcModelItemType").ITEM_DTL_NOTE) {
              if (item.GetDetailType() == pfcCreate("pfcDetailType").DETAIL_NOTE) {
                      var detailNoteInstructions = item.GetInstructions(true);
                      var content = "Got Error to modify note: "
                      var textLines = detailNoteInstructions.TextLines;
                      for (j = 0; j < textLines.Count; j++) {
                          var texts = textLines.Item(j).Texts;
                          for (var k = 0; k < texts.Count; k++) {
                              content += texts.Item(k).Text;
                              texts.Item(k).Text = texts.Item(k).Text;
                              item.Modify(detailNoteInstructions);
                              if (texts.Item(k).Text == name2){
                                texts.Item(k).Text = name;
Creo 9
I resolved the issue.  The *** was being broken into a seperate text.item, so I updated my code to reflect that.  Below is the functional code.
  if (pfcIsMozilla())
  session.CurrentWindow.SetBrowserSize (0.0);
  if (model == null)
      return;
      return;
  var LABEL3 = "\*\*\*";
  var name3 = String(LABEL3)
  var LABEL4 = "&REF_DES:ATT_CONN";
  var name4 = String(LABEL4)
  var LABEL5 = "LABEL: \*\*\*";
  var name5 = String(LABEL5)
          item.Erase();
                              if (texts.Item(k).Text == name3){
                                  texts.Item(k).Text = name4;
                              if (texts.Item(k).Text == name5){
Erase (hide) the note before edit. Then show (display)
That didn't do it.  I didn't realize before.  It's actually crashing on these notes unless the textbox has been double clicked.
EDIT: Nevermind.  It's not crashing on those.  I just had a bug.  It's still not working as intended.  It's not changing them.  I can see them being hidden/unhidden.
For reference, I attached a picture of the note, as well as the code with your suggestion implemented.
function maketable (point)
  var drawing = session.CurrentModel;
  var noteedge = pfcCreate ("pfcSelectionOptions").Create ("prt_or_asm");
  noteedge.MaxNumSels = 1;  // Only select one edge per loop iteration
  var selections = void null;
  try {
    selections = session.Select (noteedge, void null);
  catch (err) {
    if (pfcGetExceptionType (err) == "pfcXToolkitUserAbort" ||
        pfcGetExceptionType (err) == "pfcXToolkitPickAbove")
      return (void null);
    else
      throw err;
  if (selections.Count == 0)
    return (void null);
  var seledge = selections.selmodel;
  //var fullname = seledge.getfullname()
  //var pntSel = pfcCreate ("MpfcSelect").CreateComponentSelection (seledge, void null);
  //var pOwnerA = seledge.getfullname;
  //var p = drawing.SelectParameters();
var widths = new Array ();
widths [0] = 5.000;
widths [1] = 9.000;
widths [2] = 12.000;
widths [3] = 5.300;
widths [4] = 7.000;
//var entryarray = entries ();
var tabinstrs = pfcCreate ("pfcTableCreateInstructions").Create (point);
tabinstrs.SizeType = pfcCreate ("pfcTableSizeType").TABLESIZE_BY_NUM_CHARS;
var columnInfo = pfcCreate ("pfcColumnCreateOptions");
for (var j = 0; j < widths.length; j++)
  var column = pfcCreate ("pfcColumnCreateOption").Create (
              pfcCreate ("pfcColumnJustification").COL_JUSTIFY_CENTER, widths [j]);
  columnInfo.Append (column);
tabinstrs.ColumnData = columnInfo;
var rowInfo = pfcCreate ("realseq");
for (var k = 0; k < 1; k++)
  rowInfo.Append (2.3);
tabinstrs.RowHeights = rowInfo;
for (var k = 1; k < 5 + 2; k++)
  rowInfo.Append (1.0);
var dwgTable = drawing.CreateTable (tabinstrs);
var topLeft = pfcCreate ("pfcTableCell").Create (1, 1);
var bottomRight = pfcCreate ("pfcTableCell").Create (1, 5);
dwgTable.MergeRegion (topLeft, bottomRight, null);
writeTextInCell (dwgTable, 1, 1, "REFDES" + "\n" + "("+")");
writeTextInCell (dwgTable, 2, 1, "PIN");
writeTextInCell (dwgTable, 2, 2, "TERMINAL");
writeTextInCell (dwgTable, 2, 3, "TERMINAL AWG");
writeTextInCell (dwgTable, 2, 4, "COLOR");
writeTextInCell (dwgTable, 2, 5, "WIRE #");
  For each entry port...
for(p=0; p<entryarray.Count; p++)
    var entry = entryarray.Item (p);
    writeTextInCell (dwgTable, p+3, 1, entry.Item());
    writeTextInCell (dwgTable, p+3, 2, term.Item (0));
    writeTextInCell (dwgTable, p+3, 3, termawg.Item (1));
    writeTextInCell (dwgTable, p+3, 4, color.Item (2));
    writeTextInCell (dwgTable, p+3, 4, wirenum.Item (2));
dwgTable.Display ();
  if (pfcIsMozilla())
  if (model == null)
      return;
      return;
          item.Erase();
                      //var attach = detailNoteInstructions.Leaders;
                              if (texts.Item(k).Text == name2 || texts.Item(k).Text == name){
              item.Show();
  if (pfcIsMozilla())
  if (model == null)
      return;
      return;
          item.Erase();
