I have set following settings:
Model Properties /Detail option
default_annotation_font arialn.ttf
symbol_font ISO
same settings in drawing properties
All symbol come in arialn.ttf but only the diameter symbol (by pressing button add diameter symbol to dimension) stays in old legacy mode (see picture - only lines no ttf font)
Strange thing is - when i manually add the diamter symbol as prefix it is correct (see second picture)
How can I fix this?
symbol_font ISO must be set in drawing model, too.
Yes, its set ISO - but I still have this old Legacy Diameter.
I guess that the old diameter symbol was added to dimension manually.
Yes, its set manually to the dimension via the dedicated menu button,
you cannot expect that Creo will replace manually added special character automatically.
We ran into that issue as well. We ended up setting the model and drawing to:
symbol_font stroked_asme
symbol_font stroked_asme - Doesnt change anything for me.
I set it to ISO by default
Can you create a dummy part and drawing and then share?
