@LM_12739295 With reference to your topic
May I ask which jdk version you use on Creo 7.0.9. I am using Creo 7.0.0.
Cause I am totally a beginner. I compile the code in otk_java_free\otk_java_appls\install_test and load it in creo. But only if I compile it with jdk1.7 can I load it. Even so, when I click the <Jlink Install Test>, It open the default .prt file and after a while alert the message "Installation Test has failed". Using other jdk version such as 1.8, 11, I can't even load it to creo.
Hi can you confirm you went through that article : https://www.ptc.com/en/support/article/CS000321882
Also according to the troubleshooting guidelines it should be JRE 8
Hello @LJ_13692736,
It looks like you have a response from a PTC support expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
